[Solved] Sum of Items on different Sheets?
Ti-Paul
Hi, I am fairly new to this, Can you please let me know if there is a way to get a sum of ex: A2 if it is produced in any of my tabs at the bottom? There is a chance that any of my items can be produced many of times thru out the year and I would like to keep a track of how much we produce of each Product No. On the TEST SHEET tab is where I would like to get the information from every other tabs or sheets not sure what to call them. I would like to bring back the totals from column L, M, N, O and P if possible please. I have attached an example of my excel sheet, this will be updated each day with last nights production. Please and Thank you!
Hello Ti-Paul,
You can total a specific Product No across multiple sheets using this formula; no VBA needed.
First, list all the sheet names (except the TEST SHEET) in a range, say X2:X20, and name that range Tabs.
Then use this formula in TEST SHEET!L2 (assuming the Product No is in A2):
=SUMPRODUCT(SUMIF(INDIRECT("'"&Tabs&"'!A:A"),$A2,INDIRECT("'"&Tabs&"'!L:L")))
This adds all values from column L across every sheet listed in Tabs where the Product No matches A2.
Just copy the same formula for M, N, O, and P columns by changing the last column letter.
It’s an easy and dynamic way to sum matching items from multiple sheets.
Oh perfect, Thank you. Just a question please. Sorry just learning this, does this search for the PRODUCT NO in a specific cell ex: A2 what if that PRODUCT NO is in a different cell will it still pick it up and bring back the value? Thank you for your help!!!
Hello Ti-Paul,
You’re very welcome, and great question! Yes, the formula looks for the Product No that’s in the cell you reference (in this case, $A2).
So, if your Product No is in a different cell, for example, B2 or D5, you just need to change $A2 in the formula to that cell reference.
For example, if your Product No is in B2, the formula becomes:
=SUMPRODUCT(SUMIF(INDIRECT("'"&Tabs&"'!A:A"),$B2,INDIRECT("'"&Tabs&"'!L:L")))
As long as you update that reference, it will correctly find and sum the matching Product No across all the sheets listed in your Tabs range.
BEJOTOTOGACOR
