Missing Gridlines
Kata Davis
All of a sudden, the gridlines in excel are not showing by default. Every sheet I open I have to go to advance setting options and click the black gridline color option. I've tried all the troubleshooting suggestions, and nothing is working. Please help!!!
Hello Kata Davis,
It sounds like Excel’s gridline color might have been changed globally, which sometimes happens after theme or display updates. Let’s go through a few checks to restore the default gridlines permanently:
  1. Check Gridline Visibility from the View Tab:
    • Go to the View tab on the Ribbon.
    • In the Show group, make sure the Gridlines checkbox is ticked.
    • If it’s unchecked, gridlines won’t appear even if they’re enabled in Options.
  2. Reset Gridline Color:
    • Go to File Options Advanced.
    • Under Display options for this worksheet, make sure Show gridlines is selected.
    • Set Gridline color to Automatic (not black or custom).
    • Click OK to save changes.
  3. Apply to All Worksheets:
    • If the issue persists, right-click any sheet tab → Select All Sheets → then adjust the gridline color once; it’ll apply to all sheets.
  4. Check Excel Theme or Display Mode:
    • Dark Mode or high-contrast themes can make gridlines appear faint. Try switching to Light Mode to confirm.
  5. Repair or Reset Excel Profile (if needed):
    • Close Excel → go to Control Panel ➜ Programs ➜ Microsoft Office ➜ Change ➜ Quick Repair.
    • Or start Excel in Safe Mode (Ctrl + click Excel icon) to check if an add-in is causing the problem.
Please try enabling View → Gridlines and setting the color to Automatic, this usually restores the gridlines permanently.
Hello Kata Davis,
    • If the issue persists, right-click any sheet tab → Select All Sheets → then adjust the gridline color once; it’ll apply to all sheets - if the issue with the money is still on you better play some games on https://wincraft.casino/ka
Oh thanks for this answer!
yandexdireWeaph
