[Solved] Is there a formula to create cell D1 from A1 .... image example
You can achieve this by using a formula that inserts a line break between "Top" and "Bottom." In cell D1, enter:
  • After that, make sure Wrap Text is enabled for cell D1 (Home tab → Alignment group → Wrap Text).
  • This way, the space in A1 will be replaced with a line break, and you’ll see "Top" on the first line and "Bottom" on the second line inside D1.
backlinkupseo
