[Solved] Help Merge
GIC David
I need to merge the duplicates names at the same address so that only 1 line remains for both people. So Bill @ 123 main St and Jane @ 123 Main St become Bill & Jane @ 123 Main st.
41099 Ms. Alyssa J. Aiello 1109 W Washington Blvd Apt 6D Chicago Illinois 60607-2116 Ms. Aiello
43667 Ms. Gianna Aiello 1109 W Washington Blvd Apt 6D Chicago Illinois 60607-2116 Ms. Aiello
to become
41099 Ms. Alyssa J. Aiello & Ms. Gianna Aiello 1109 W Washington Blvd Apt 6D Chicago Illinois 60607-2116 Misses Aiello
Hello Gic David,
You can achieve this in Excel using the Power Query tool, which is perfect for combining rows based on matching addresses and merging names into a single line. Here’s a step-by-step guide:
1. Load your data into Power Query
  • Select your data range.
  • Go to the Data tab >> choose From Table/Range.
  • If prompted, confirm your table has headers.
2. Group by Address
  • In Power Query, select all the columns that make up the address (for example: “Address”, “City”, “State”, “Zip”).
  • Go to Home tab >> select Group By.
  • In the Group By dialog, for New column name, enter Combined Names.
  • For Operation, choose All Rows (or if you only need the Name column, choose “Text Combine” and select your Name column, with a separator like “ & ”).
3. Combine Names
  • If you used “All Rows”, click the expand icon next to the new column and select just the Name field.
  • Use the Text.Combine formula to merge all names with “ & ” between them. Example formula:
= Text.Combine([Names], " & ")
  • You can also use Add Custom Column and write:
Text.Combine([AllNames][Name], " & ")
4. Recombine Other Data
  • Keep the address fields as is (since they’re the same).
  • Add any needed static text (e.g., “Misses Aiello”).
5. Close & Load: Once finished, click Close & Load to put the merged results back into Excel.
88clb0net
